White Clio 1.2 @ 172
Ok So I got my car back from the bodyshop after a lengthy 18months.
The donor car for the 172 Engine was a Mk2 Ph2 and was in full working order when it went into the bodyshop. Seems the Clever peeps @ the bodyshop had the car jacked on the gear linkage point whilst the car was in 3rd gear and it seems to of broken something inside the box *facepalm*
Symptoms;
* Car is stuck in 3rd gear
* Gear linkage feels soggy
* Disengaging the clutch puts the car into 'neutral' i.e. it does correctly disengage but moving the gear rod does absolutely nothing.
* The speedo sensor (I think) on the side of the box has been sheered off.
Now my question is, what could this possibly be is there like 101 things it could be or is it just a plain and straight answer. TBH My knowledge on gearboxes isn't the best I understand the very basics and fundamentals of how they operate but that's as far as it goes.
Secondly with the above named issue hopefully being pointed out as a single point of failure i.e. "yes its the gearbox linkage inside the box that has broke" or something along those lines is the box salvagable and repairable and what if any parts do I order to get the issue rectified?
Lastly thanks in advance for the help
Regards Dean0
Symptoms;
Regards Dean0
