Gearbox/diff noise
I bought this car and drove it home. It wasn't making the noise then.
I changed the clutch and i drove it to and from the mot place and it's noisy as hell.
Possible causes?
I can't believe i have broken the diff/gearbox...
Video of noise. Changes with throttle so thinking it's diff related.
I put oil in until overflowed out.
Everything is tight i believe.
BashRacing
270nm is the proper setting IIRC but shouldn't be the issue,
Does it makes noise stationary with the clutch depressed/released or is it just when in motion?
I can't remember i looked it up as i was doing it. So I'm pretty sure it was the right way round. If it was the clutch wouldn't it be all the time?
NorthloopCup
Not necessarily mate no. The clutch is under pressure when the pedal isn't pressed. Does it go if you press the clutch? It sounds more like a vibration noise to me.
When driving along if i dip the clutch, yes it goes. Coasting in neutral it goes, with clutch up it goes.
What will happen if the clutch is the wrong way round?
I did think when i was looking at it, it was the same. As it had the same casting where the speedo sensor goes on the cup box. It's just it looked like it was filled.
I will get a picture up asap.
Upload a picture of the other box you've got mate. I'll be able to tell you if it's a useable box. Some of the ph2 boxes are still 129's, but they just don't have the speedo sender fitted.
Wasn't sure what angle you needed!
