gearbox mount
Car  clio 172 cup running 201
hi just wondering is there any instructions on how to change a engine mount (gearbox one) on a 172 mk2, i have done a search but maybe missed something thanks for help in advance:)
- remove the battery (exposing the mount)
- support the gearbox with a trolley jack
- remove the three bolts/nut.. the nut in the centre of the mount will likely be tight - 'shock' it round to start it. the nuts that hold the mount to the alloy armature aren't captive, so you'll need to catch them as they fall from underneath
- remove the old mount (may need to huft things about to get it off)
- once it's off, tighten the exposed shaft - there's a flat on it. it screws into another nut under the gearbox (difficult to get to)
- replace mount
that's about it for the upper gearbox mount. is that the one?
