Gearbox oil change?
  Clio 172 Sport
Hi guys,
I have a slight crunch at high revs when changing from 2nd into 3rd and was wondering whether it was worth changing the gearbox oil or is it something more serious?
Luke
  330i. E30 Touring.
Check the level of the oil- if it's low it could have been a contributor to the crunch, but no, i very much doubt it'll fix it.
3rd gear synchro is the usual culprit here, and will be fixed by a box refurb.
  Clio 172 Sport
Might well change the oil then and see if that helps...not that its a major issue at the mo as i only notice it on the track rather than any road use.
Cheers guys
  dan's cast offs.
synchro's on way out on third, you could try an oil change and might be lucky. other than that just change into third a bit slower.
ADS_V6
  172 cup clio v6 st
hi whats the best gear oil changing mine on weekend, is it the renault elf one,or is total 75 80 ok as the elf is quite pricey. Happy new year all
