Gearbox oil for 182
  Clio 182
whats the best gearbox oil to use in a 182?
How much needed?
Shall I drain old stuff out?
How do I fill and drain please peeps?
dann2707
Elf 75w/80
3 litres is required
Of course you should drain the old stuff out haha. Drain plug is from below but can't remember what size.
To fill it up there is a wingnut that is on the front of the gearbox facing the radiator that you unscrew with your fingers, stick a pipe in like a hose pipe and funnel then fill up from above. Easy :)
  172 Cup
As above but the gearbox holds 3.1 litres so I would buy 4 so you will have enough and some spare
  Pug 206 SW, 172 CUP
I'd buy the extra litre for the simple reason that having a gearbox that doesn't weep from the selector shaft seal is a rare thing. I topped mine up again this year and gave it a clean.
