Gearbox oil guide.
  320d
In the guides section there is the Gearbox oil change guide, however the pictures are gone. Dones anybody have a guide with pictures?
I want to change the oil to keep the boxc in good condition if possible.
no pictures, but there's a drain plug at the back of the gearbox (need a new copper seal), and you refill it via the plastic 'wingnut' on the front of the gearbox (behind the radiator - need to remove airbox). there's a separate seal behind this wingnut, but should be OK to reuse
they take 3L 75/80 GL5 spec gearoil; easiest to refill using a short length of hose pipe/similar - with car level, refill until it overflows from the filling aperture
check for leaks (particularly from gear selector and n/s driveshaft) and make sure engine mounts are good (worn mounts will encourage oil leaks)
ed. as 172Ben
Darren S
I've not changed the gearbox oil myself on mine, but it has been done three times in its 62k life. I think it's worth changing more regularly than is recommended - it certainly can't do any harm. :)
D.
D.
Don't Renault say it doesn't ever need changing? I wouldn't fancy risking that lol.
Filling the box up looks a right pain in the arse, it was hard enough just trying to undo the wing nut lol.
