Geometry settings for Spax RSX Track kit and Whiteline setting?
len_beach
Car  E92 M3,172 track car
I know this is personal preference but as a start point, what should I be asking for?
The car is track use only other than being driven to and from.
The front is currently around 15mm from the lowest setting and the rear is as low as it will go and both are 12 clicks from soft.
What toe and camber should I ask the guys to dial in?
Also, the Whiteline instructions aren't the clearest. It currently has around 12mm of thread showing above the bushes which I think is medium?
I have the same setup.
I have 1.5 deg neg camber, 12mins toe out.
The whiteline is set to its softest setting.
A friend who does setups on racecars was wondering if tbe rear wouldn't be too stiff though......time (and a good roundabout) wil tell:)
I got recommended -1.5 on fronts for track/road driving so I would be looking at that as a rough guide. You might want to try -2 and take it from there, as for toe I was told to set it dead straight.Other people will say different but each to their own.
