Rust on the rear archs
Rust ont he back of the boot (they all do it though) rust on the bottom of the drivers doors plus the sills.
Damaged jacking points/bent sills.
Check the PAS pumps Ok (if its ok then its got to be faulty they all are bad)
Check for play in the stearing column (common problme easy ish fix just get it welded)
Check the electrics
Check the rear brakes + handbrake preferably on a hill if so its worth £1million
Check for service hisotry and oil level plus all gauages work (oil level only works for a few second)
check the oil pressures good (3.5bar at 3k or so) check it does up and down with the revs (abeilty slowy its no instant response)
Check the car idles and start from both cold and hot.
Check to see if they have both keys. (pain to replace as there expensive)
Check the car drives an brakes in a straight line (hand braking)
Check the sunroof leaks as it should do on the electronics (joke but they all do)
Lift off throttle at high repm check for smoke backfires etc. Engine quite bulletprof though. Aso check when you lift off it don't knock out of gear but its easy fix just new mount.
Check heat shield is there its very important to be there £50 new.
