Mbeau
Clio 172
Hopefully this is the right area to post this. I have a 1.4 TSI Golf Mk5. Also know as the twin charger as it has a supercharger and a turbo.
Runs great and returns good MPG. However I cannot get it through emissions on the mot. It has high co2(over 3.5) and low lambda reading.
I have taken plugs out and all look good. Replaced both pre and post cat lambda sensors. Replaced cat with good condition used item. The current one had only done 35,000 miles. Car is up to temp when tested. Replaced all four pecil coils. It has never run so well! The guys at the mot station are good and very helpful.
On live data the coolant temp sensor is showing 90 degrees C. The only thing I am slightly unsure of it the purge Vale reading which is 2.4% on idle and 9% on patrial throttle. From what I have read this should be 0 or 100%
Can any one offer any advice. I am going to replace the coolant temp sensor and purge valve tomorrow. I don't normally admit defeat, but this is beginning to test my patience!
