Good Pads or Discs?
Car  172
Hi
just wondering what would give me better breaks. buying new discs as mine are worn and buying good pads
or
just buying good discs, my pads are already quite new but just standard
any advice welcome cheers
Hope you changed the brake fluid as well. There are plenty of suggested upgrades listed on this forum, all are favourable with Cliosport members so you can't go wrong with what has already been mentioned. Taking a big leap in braking performance will cost though, such as 4pot drake calipers.
DS2500's, Brembo HC discs, fluid change and braided lines is your best bet for comprimise between daily drive and decent stopping power.
I've got the Brembo Max and the Pagid Blue RS + braided brake lines + RBF600 brake fluid and the brake is awesome !! I left standard on the rear
But the pagid are noisy when they're cold but when hot it's really good !
Unless you plan to take it on the track, standard pads will be fine for your 1.4. Same goes for the discs though aftermarket versions are usually cheaper than what Renault would charge you.
I agree with Jon. Generic OEM parts from eurocarparts or similar will surely be fine. Have you measured your discs to see if they actually need replacing? If you feel like spunking money for the sake of it maybe try some DS2500s.;)
