Got a leak :(
  Looking for a ph-quick...
Yep, Shes poorly..... Theres a slight water leak. It seems to be comming from one of the two metal water pipes that run paralell to the cylinder block. its a slow drip about one every second. im hoping its just the pipe split.
Has anybody had this before?? Valver experts...i could do with some advice!
Also on the way home earlier the temperature gauge was really eratic, was at the normal temp, then its dropped right down??? was really strange?
Help
Thankyou
Amir
Right kicked up a bit more dirt on this leak, It only seems to leak when the engine is off. wen it running it doesnt seem to leak!!
Any ideas??
Amir
well the water level from the expansion tank is dropping so its definately a leak...
