Grinding Noise when Turning wheels
Car  Titanium Clio 182
I have been getting a noise when I drive at 60mph its hard to explain it, I though it was the engine or exhaust at first but when I put my foot down on the clutch to lower the revs, the noise was still there.
I individually raised each side of the car and spun the wheels, all of them where grinding when I spun them. My car has been sitting in Portsmouth dockyard for 2 months and the brakes where stuck on. For about 5 days after moving the car the brakes where lumpy as if there was something on the discs (was probably rust) the brake discs are still rust but the brakes seem fine now.
Could this be a problem with my brakes or a bearing, i'm thinking brakes.
does the grinding sound come from the wheel hub or towards the gearbox?
not likely to be both wheel bearings gone at the same time i should imagine...
When turning every wheel there is a grinding noise from each. When driving at 60mp it sounds like its coming from the rear.
When I turned them by hand yeah.
Like I said the car was parked up outside for 2 months and the brakes were stuck on. Maybe thats the cause of it all.
I get a weird noise come from my car now, need to get it serviced next month.
I had a noise come from my car but it turnt out the wheel was rubbing, you checked it?
On the front wheels I wiggled them and they had a slight bit of give moving them left to right, i'd say probably just under a mm movement, I dunno if that was just the steering though.
