think its rear as front disk/pads look fresh and no grooves on disk
how ever when the gf breaks the rear drums seem to grind, i have removed the drum there is deffinetl 3mm of shoe material left, i sprayed them with break cleaner re assembled it and it was fine for two days now its grinding again,
only grinds under breaking :S
might change the shoes see if it changes anything
her winging and me not being able to see a problem is annoying me now![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
haynes manual says friction material minimum 2mm maybe i have gone over 2mm and it meant to grind to make you change them? :S
