GRP / Fibreglass Bonnet - Stay Support
Car  Clio 172 (CUP)
Before I go and transfer the OEM bonnet stay to my new lightweight bonnet, do others on here have a better solution for supporting the bonnet that's lightweight/simple?
...a wooden broomstick handle is not suitable as it means I've still got to carry it around [emoji3]
I know it’s an old post, but has anybody else found a better solution than reusing the original bonnet stay with a fibreglass bonnet?
Maybe supporting it in the centre but then you have an obstruction when working under the bonnet.
The oem stay is a no-go.
Thought about it for mine but the bonnet twist a lit under its own weight. Not like It
On my track car I fabricated a nice long aluminum pipe (14mm in diameter) with one rubber end and another plastic pointy end.
The pointy goes in the square hole near headlight, the rubbery end goes in one of the recess of the bonnet, where oem got those squarish holes.. it hold well and its handy when working.
Yes you have to carry around if you need it.
I've seen some guys use those premade telescopic curtain bars.
Wow, didn’t realise they were that fragile
Think of it like those de skinned metal ones. But made of fiberglass which is way more flopsy being that big.
Plus it needs to be light.. so.. at fixings is strong but where its not needed it has been left light and thin.
I weighted everything as I am obsessed, and oem metal one was 11kg, my fiberglass (further trimmed because of itbs) was around 3.2 without catches and paint. So you can imagine yourself its strength ehheh
