Try abit of fault finding, see witch cylinder isn't firing, then try swapping a plug with another cylinder to see if it changes, then try the same with a lead
Check to see if you have condensation in the spark plug wells, i had this last week. Dried up the leads/plugs and the problem is solved. Try this before spending money on coil packs/leads/injectors etc.
All sorted! Took all plugs out and gave them a clean up, dried up the oil I had spilt on last oil change, cleaned the throttle body and it still did the same so while it was plodding I wiggled the ht leads coming off the coil and hey presto it suddenly started firing on all four. I would imagine the leads are on their way out or just a dodgy connection.
I also rubbed down the renaultsport on the top of the inlet manifold while it was out with some wet and dry
Spoke too soon, it seems to be intermittent so does that point to the leads and rule out coil as I've checked all connections. It was fine yesterday but my battery is a due replacing too, this can't be related can it? Dom
