Guide for checking/replacing 182 injectors?
  Arctic 182
Is there a guide anywhere showing how to check the injectors in a 182/how to replace them?
Had a look in the guide section but had no luck, if here is one could somebody point me in the right direction?
If not, can i have some info as to how to do this, I dont have a clue!
Trainerbrow
  Mk1 Audi TT 3.2 V6
Fuel rail guard off with 2 x 10mm/13mm nuts
Fuel line off.
Undo two bolts
Pull very hard
Trainerbrow
  Mk1 Audi TT 3.2 V6
Is it missing/running lumpy? If so, just unplug each injector at a time. It should run like utter s**t each time you unplug one. If one makes no difference, thats your shagged injector
  Arctic 182
It doesn't seem to be, but I did the dashboard fault check thing and it said there was an injector fault so thought I should check them?
  Arctic 182
And the engine management light is on...would an injector fault cause it to be or is that likely to be something else?
