Whats the best way to set these up?i currently have it all the way down on the back and very slightly lower on the front!is this the best way to have it or should the rear be sitting lower?or should the car be level?this is on a 172 cup!cheers
correct me if im wrong but do you not need quarter scales to properly set up coilovers? ohterwise the car could completely fly off the road going round a corner? you need to get it set up by a pro who has that equipment so that all the weight is being distributed accordingly.
and regards to corner weighting the car all depends on the driver really
id say with a clio you would want a very low rake 0-10mm, and as fred says slightly higher on the drivers side front to balance the front weighting out
