Might have been switched off.... Turn your ignition on, then turn your side lights on and off twice and you should hear a beep....see if they work then.
but u can switch the auto lights setting on/off.
1. put key in, 1 turn/click.
2. turn the headlight twister from the off setting to the dipped beam setting and back, do this twice. quite quickly.
3. should hear a beep (or double beep, cant remember).
then turn engine on and see if the lights come on (if dark)
