Handbrake adjustment advice
Car  Renault Clio 172 16V
Hi there
I have a problem in which the hand brake doesn't hold the back left but on back right it's too much. Releasing the handbrake on the right rear is as if it's still on and you can barely move the disc!
Needs to be sorted today while car is up on jacks, how do I do this?
Renault clio sport 2.0 16V 172 2001
Two new cables I reckon. Sounds like one is stretched.
Ph1 is inside the car, Ph2 underneath the car. I think or the other way round.
2001 could be either!
Thanks DannyR :)
Does anyone know exactly where the adjusters are? Couldn't see one at the handbrake with cover off
Then yours will be underneath, if it's in car it's under handbrake cover which pulls off.
You can only adjust both at the same time too if I remember, and if they need replacing they have to be done as a pair.
The cables seem to disappear underneath the exhaust shroud, can't see it. Can't see anything inside the car either under handbrake cable.
