glasgow182 said:
whats type of brake fluid should i use then ?
Any Dot 4 brake fluid mate some people like to go for more expensive stuff like castrol response or silkolene , but bog standard halfrauds stuff will be ok . If you say your pads are ok the level will most likely be low . Check the cap on the brake fluid bottle , see if its come loose . Just top it up and make sure its tight .
Mine used to come on alot round certain bends if i was pushing it .
As to the rear pads sticking when setting off after being left a while , my 172 did this for a couple of months , my 182 did it for a couple of weeks , 5 weeks old now and its stopped doing it .
