VenomUK
Clio 172
This isn’t a Clio question but I’m of the thinking that the process may be the same across the models.
Basically on my 2012 Kangoo 1.5dci I had the clutch replaced along with the pipe with the inline damping as it was rotten and was leaking fluid. Since having it back the selection has been awful! The bite is right at the bottom to the point I physically can’t get it into gear unless the engine is off. I gave it back and had it bled again, and it was a little better but still at times the peddle feels like there’s no resistance and the bite is so far towards the bottom of the pedal. After a few pumps it does like to select gears. At times it is nice and smooth but most of the time it can be very hard to change gear. When it is hard to select gear and It goes into 1st you can feel the clutch dragging as the pedal is fully compressed.
I’m assuming there is air still in the system after the second bleed and that perhaps the bleeding process hasn’t been done correctly or there is trapped air in the system somewhere?
Can anyone throw some advice my way for bleeding the clutch or if there is something I am missing. Looking at the bleed nipple it looks as though it is the 2-stage clip where you pull it out to the first click before bleeding can begin.
