Harness fitment question
Car  Clio 172 Cup
Got my harnesses delivered to day and cant find a good place to fit the lap straps, just wondering what you guys have done and any good suggestions as i cant find anywhere to fit the inside one nearest the hand brake ???????
Where the seatbelt tensioner is bolted to the seat hand brake side. The bottom seatbelt point on the other.
yeah was gonna use the existing belt point as said but on the other side there isn't one cos ive replaced the seats
either use the bolt by the handbrake that holds the subframe or get a long eye bolt to replace it with. depends what harness you have.
If you have d clip type harnesses then for the centre point as said a long eye bolt and nut underneath where the original seat used to bolt trough.
FYI the outer lap belts on the b pillar can be secured with an m10 eye bolt through the original fixing point and the rear two with 7/16 UNF eyebolts through the original rear belt fixing points (not ideal but its the only good fixing point on a standard car without a cage or a bar welded in)
I drilled new holes for the inside lap strap eye bolts to avoid using the same hole that the seat is bolted through,
Using spreader plates on the under side of the car, ill post some pics later if it helps,
