Of the interior blowers not working, the climate control display works fine but the fans wont work on any setting:S
this problem is intermittent, they will work now and then say every few days!
any help appreciated
Its the resiter pack common problem.
£85 for a new one its under the scuttle panel of the car. You can fix your old one up but unless you know what our doing forget it
The problem is it sits in the scuttle pale and gets wet.
Scuttle panel is down the bottom of the windcreen remove it there a fewlittle click i forget the type I think you push them in and remove the drivers side bit of it (you need to do this under the bonnet remove it and you'll see the air system there a few wires going to a small boc thats the resister pack.
