Have KTec sent me the wrong brake pads?
Car  RB Clio 182
Hiya,
I ordered some Ferodo DS2500 pads from KTec and on the pads it says -
Fronts - FDS565
Rears - FDS588
I have taken my front wheel off and checked it against one of my OE front pads and it seems to be the same size. My only concern is two of the four Ferodo front pads have a brake sensor wire on it but my old one do not?
So my question is can I use these pads on my Clio 182 54 plate or should I send them back?
I would ring them but they are now closed! grrrrrrrr
They should not have sensors on them, so assume they are wrong. They should have ds2500 printed on the back of the pad
that's not a DS2500 part number, i reckon they've sent you the DS Performance pads
edit just checked, they will fit, but they're NOT from the race range, they're the road range ie DS Performance
future reference, DS2500's are £95 delivered from me ;)
http://www.k-tecracing.com/show_product.asp?id=2688
Found what they have sent me on their website. That picture in link above is what I have in front of me - Fronts - FDS565.
http://www.ferodoracing.com/catalogue/detail_car_tuning.php?cat=brake_pads&code=FDS565
Ferodo website says these pads arent suitable but they look identical to the FCP565 (front) and FCP558 (rears) which do fit in the link below......
http://www.ferodoracing.com/catalogue/detail_car_racing.php?code=FCP565&cat=brake_pads
Does anyone know if the ones I have been sent will be ok if i fit them?
Im going to be having a right go at KTec on Monday!!!!!
some Renault specialist they are!!! stocking and sending out parts that arent even for a renault........
Before Badmouthing them, how about speaking to them first, If its a Genuine mistake I am sure that the team at K-Tec will put it right, they are usually bob on as many a person on here will vouch for.
TBH giving them a going over before trying to sort it out is not really fair, and is less likely to make them as inclined to help you (Well it would do me).
they've just sent you the DS Performance instead of the DS2500, simple enough mistake to make
the ones you have will fit
yeah they seem to fit.... should i just cut off the brake sensor wire?
i really wanted ds2500s but since i need my car tomorrow ill have to make do.
