Dynamique 1.2 16v
Hope so haha! Cheers again mate
Where abouts does the power cable go? Just unbolt the main positive wire pop power cable ring terminal over, and bolt back up? And is the negative terminal I disconnect before working on electrics? And take the fuse out of the power cable? ( fuse end close to battery right) cheers guys x
yeah disconnect your negative side. undo the nut on the positive side and connect the power cable using a ring terminal and do the nut back on. don't connect the negative until you have finished the install. try to get your fuse as close to your battery as possible. (within 12 inches away is good enough) good luck mate
Find an access point or grommet you can feed the cable through on my 172 I went under the coolant bottle behind the carpet, there an unused grommet that comes out in the passengers footwell.
Right I've got all wires installed connected to power wire to battery but haven't sort cables in the boot of the car yet! Started to rain so had to abandon ship!! I connected the power wire to battery before the rain, an have now had to connect negative back to battery to lock the car?! The power wire doesn't have a fuse in the fuse holder yet, will it drain the battery or not?
