haynes manualy info needed
non ABS
a) right hand rear b) left hand front c) left hand rear d) right hand front
ABS
a) left hand front b) Right hand front c) left hand rear d) right hand rear
Cheers "cliosportcraig" - night.icon posted this thread for me as i forgot my haynes manual. John phoned through with the above details.
Thanks john, craig.
  172 cup,s2 rs turbo
if its got abs then dont let the system run completly dry of brake fluid and turn the ing on.if you do the abs block does a self test and draws air out of the brake pipes and into the block.virtually impossible to get air out of the hydraulic block on older models.
you start with the furthest caliper away, just makes sure no air gets passed of from other lines or gets stuck.
