Hazards wont stop flashing
does the stereo have to come out to get the hazard panel out??
No it doesn't i pushed the hazard switch so it was out then got a little screwdriver and popped the little plastic triangle off then pushed the little clips out and the switch came out.
ah cool, thanks :) will have a go at that before i get the scuttle & wipers off.
anyone know how to get them off, just 2 13mm on the wipers im guessing, then some little screws on the scuttle?
Yep, you wont be able to see the connector block on the unit though. You will need to unscrew the cap where the wires dissapear to get to it ;)
