Head gasket change
Car  Williams2-10th Clio Owned
Pretty certain i know how to....but have i missed anything?
lock crank out where cam pulley markers line up, strip down, take head off.....check gasket and for warping of head, build it back up, head bolts torqued up in order, re-line pulley to markers, tension up cam belt.
Turn engine over from crank forwards and backwards before starting engine.
No it's a Ford KA! been told i shouldn't turn the engine backward, apart from that does the above seem ok?
yea thats fine, Turn the engine twice and make sure its all lined up, the marks on the belt WILL NOT line up after the engine has turned, just make sure all the other marks do.
