headlight adjustment
Car  Mk II silver 172
Need to adjust the headlights as they seem a little low. How do i do this on a mk2 172 as the 'generic' handbook says about turning the trundle wheel but this just adjusts the dash brightness. Thanks
Is there not a dial next to it? For headlight level adjustment? Mt cup has it although if you have xenons you may not have it, some else will help you there.
You can manually adjust them by turning the white hex-head screw behind the headlight. Don't blame me if you c**k it up tho!
I would park up infront of a garage and mark where they are now so you can put it back to original if needed
