Headlight correction, done using everyday tools. Could be used as a guide, very detai
  • Thread starter Thread starter jakm15
  • Start date Start date
J
jakm15
All the Clios seem to suffer from the headlights deteriorating due to UV rays, wear and tear etc. Here’s how to sort it out with normal tools for a minimum cost. Give it a go it’s easier than it looks and hard to mess up.
Here are a few before pictures.
Here is what you need and how it’s done step by step.
Step 1:
You need, drill, buffer drill bit, various grades of wet and dry, tape, auto glym SRP, meguiars scratch-x 2.0, 2 cloths, Mr. sheen, bowl+water, all these are available from Halfords.
Step 2:
Mask up the area
Step 3:
Start with 600 grade
Step 4:
Wet it and rub away until a consistent finish is achieved, I found it to smell of old sello tape at first
Step 5:
Next move to 800 until and consistent finish is achieved
Step6:
Finally move on to 1200 until a smooth consistent finish is achieved
Step 7:
wipe dry, it should all look the same, if not rub with 1200 until achieved.
Step 8:
Put a few blobs of meguiars scratch x 2.0 on the buffer, do not press to hard with the buffer or you brake it like the second picture
Step 9:
Buff away and keep adding more product until the finish you want is achieved, make sure you don’t catch the lens with the rubber drill bit harbour.
Step 10:
Wipe scratch x off then apply auto glym SRP with hand, allow to dry then wipe off
Step 11:
Give it a quick wipe with mr sheen
Before:
After:
Step 12:
Give the car a good wash.
Step 13:
Admire your nice new looking lights.
Any comments welcome.
Jack
This could make a good guide in the guides section.
Re: Headlight correction, done using everyday tools. Could be used as a guide, very d
did mine the other day didnt use a drill and mr shean but as long as u got the job done lol
I'm suprised you didn't just spray paint them tbh :rasp:
A drill and Mr. Sheen! LMAO!
Good results though.
christ how much product did you use!!!
did the trick :D
Good result.
I lol'd at the mr sheen too.
i thought some people would, it smells nice
haha it crossed my mind though
cheaper that a da or similar
lots and lots :D dont be stingy
Thats awesome work mate!
good effort! came up well
Lol at the tools used, but it worked and as you said - alot cheaper than a DA!
Will use this when I finish mine tomorrow :)
Nicely done.
The Mr.Sheen was a waste of time though lol
cheers makes a big difference.
thanks, the HID's seem brighter at night now, could be me but could help the light travel.
works well, if you never need a DA for anything else it does the job nicely.
i was unsure about doing them at first but once i got going thers little that can go wrong using fine grade sandpaper like those, i think ill post this up in the guides section could be helpfull to people with no pro tools.
Nicely done.
i know but my lights smell like my grans house now :rasp:
great job
fcuking awesome, well done to you. i shall be trying this myself once i have all the bits.
bravo
bravo
thanks mate, never done anything like this before but it all went swimmingly well :D
Wow. Great results! Good on you for giving it a go. They always look so old usually, but that is a cracking effort! Ghetto make-over... And a mint one at that!
thanks, i was unsure at first i thought i would wreck the lights but it turned out hard to mess up, even if you scratch them badly just work up through the sandpaper grades then it goes smooth. makes a 100% improvement at the front.
Definitely. I'll be giving it a go on my ph2 lights when they get too stone chipped. Mint.
PM a mod (green name) and get them to put it in the guides section?
ye would be exactly the same on ph2's, already done its in the guides section should help a few people who dont have a machine polisher.
Already did it on my ph2 works a treat!
