Headlight Fault
Car  182FF
Hi everybody,
Whilst replacing the sidelights on my '04 clio sport 182 the headlight has developed a fault (i say developed, i caused it). Whilst pushing one of the sidelights in the internal silver bit which holds all the lamps and is the part that is automatically height adjusted has come loose, broken or something as it only points down now and cannot be adjusted and wobbles within the headlight casing.
Does anybody know if it can be fixed by myself? Or if it can be fixed. If i could get into the headlight itself then i might be able to see what the problem is and fix it but thats another problem i have in that i cant get the headlight off.
Was hard to explain but if you want any more info just ask
Thanks,
Rich
