Headlight levels issue. Require help.
Car  BG182 FF
Hi. I removed the acoustic valve the other day and when I pulled the pipe which connects it to the airbox I clipped the headlight adjuster. Now the passenger side headlight is a lot higher than the other. I have removed it and pushed it back on but still no look.... Is it worth taking the bumper off and having a proper look to check if the adjuster is connected and push in properly.
Also surely they should never be miss aligned if its all automatic. Thanks for your help!
Sounds like you may have to move the bumper out a bit and remove your head light for a better look. May have jumped itself loose from one of the mounts/adjusters.
