BG182 FF
Hi. I removed the acoustic valve the other day and when I pulled the pipe which connects it to the airbox I clipped the headlight adjuster. Now the passenger side headlight is a lot higher than the other. I have removed it and pushed it back on but still no look.... Is it worth taking the bumper off and having a proper look to check if the adjuster is connected and push in properly.
Also surely they should never be miss aligned if its all automatic. Thanks for your help!
