Darryl_1983
RB 182 Cup
I just brought a 2004 182, and it's still got the original headunit, CD changer and speakers. So i'm looking to upgrade and need a little advise, as i've never brought or installed any ICE before.
I'm looking at getting a Pioneer DEH-4500BT headunit as i need Bluetooth, USB charging and front Aux connections, other than getting the additional cabling/connector for the steering wheel controls to work, do i need anything else?
Also looking at some cheapish speakers to replace the front and rears, i've researched the forum and found that they're both 13cm, but not found anything about depth limits, so was hopeing for a bit of advise on that. Speakers i'm looking at are Pioneer TS-G1323, mounting depth is quite small on these at 46mm, so i'd assume these would be a straight swap.
I'm not set on either of these just, what i found that, looked decent and where fairly cheap. Can get the headunti for £80, and the speakers for £30 per pair (I assume it's per pair, that is how little i know about ICE). So any advise on what might sound/work better for similar money would be great.
Sorry if this has been covered before, I could find anything searching.
