heater fan kaput
  330Ci cab
so on a drive to nottingham the fan stops working, a mate says it could be the resistor pack and renault want an eye watering £130 :( can't find one second hand anywhere. gutted
benkay
  V6 Ph2 + Audi S3(8V)
Check the guides section. About £5 and a bit of time and, if it is the resistor pack, you should be fixed.
jenic
It's well worth trying to fix it yourself tbh.
If you join the club you will get access to the guides section or alternatively there is a marketplace where you might be able to pick up a second hand one.
  Glacier White RS200
try ebay if you aren't confident enough to fix it yourself, a guy called "coolwill2k" recently did mine for me for £30 and its been fine since :)
  330Ci cab
i get the hint, its been a year lol
  330Ci cab
lol ill signup on payday, funds are allocated elsewhere and this has set me back. i'll be up the creek when my windows are hazy, so ideally i need to sort it asap. other than cliospares as they have none in stock, is there anywhere or anyone that might be selling a working item?
