Hi All,
I'm a brand new member so any help with this would be greatly appreciated.
Basically.....my climate control temperature selection doesn’t work properly
When I select a lower or higher temp on the unit the display changes to the desired temp but the blower temp doesn’t change until the car ignition is switched off and then restarted.
Once restarted the revised temperature is met straight away.
This results in me contently having to pull over to switch off the ignition each time it gets a little warm or cold in the car, not the biggest problem but annoying.
all the blower settings work fine, vent selections and air-con etc as soon as pressed, it just the temperature that is affected.
Many thanks in advance for any suggestions.
