Heaters??
  200 Gordini No.159
Right i've got a clio sport 182 sport, with the digital climate control system.
I've been having problems with the blowers, the digital system works fine and you can still feel the heat coming out but the blowers don't work, ive checked all the fuses and all of them are fine. anybody got an ideas?
thanks very much
i would say its the resistor pack that has gone, its under the scuttle panel on the drivers side held in by 2 screws and has a big plug going to it. very common fault
Theres a little plastic screw thing near the wing, push the inside of it down, remove the screw, remove the rubber bonnet seal and the scuttle panel just clips off. Its easy to get off as it allows access to the pollen filter. Youll then be able to see it.
