Basically when I put the key in the ignition and try and start the engine, this red light is flashing quickly in the middle of the speedo l and the engine won't start, as in, it does nothing at all
Nothing at all as in the starter motor doesn't turn?
If it's a mk2 , on the front of the starter motor (front of the engine bay) there's a short cable with a spade connector that powers the starter. This connector is a pretty bad design and corrodes easily.....remove it and give it a quick clean with sand paper or scrape with screwdriver/knife and reconnect.
Unless your headlights don't work or are dim...then it's battery issues
