HELP ! clio sport 172 compression
Car  Clio Sport 172
hello guys,
first time posting here,i am looking for help.
i have a clio 172 2001 and it has been misfiring in a strange way..
when i unplug injector num 3 it doesn't change anything while other injectors works well ( when i unplug,engine almost dies).
compression showed 200 on every one but on the 3rd plug (right to left) its about 70.
there is spark on both sides and on the 4 cables.
can someone help me ?
thank you.
check the injector and resistance on the injector, could just be low compression due to bore wash from dicky injector.
head is ok,i'm checking rings now
what do you mean dicky injector ?i've took them out and started the car,they are working properly.
thank you.
If one is leaking you can get bore wash and lose compression easily. As Dan says though leakdown test will tell you what's what.
