Punto/Clio GTT
ok im gonna smash all 3 pcs up soon.
earlier i set up the new cpu, all is well, i put in the new harddrive (which is my old one with vista on it) and it comes up that it wont load, nothing works.
So i decided to throw the harddrive in my pc as a slave, reinstall vista onto it and try that..... tried it and same error messege on gfs pc. The harddrive is perfect as it boots up fine on my pc so im guessing its just installing it to my spec pc and wont support the lower spec pc downstairs?
so.... i took it back out, put it back in my pc upstairs as slave, formatted the harddrive (1 hour) and took it back downstairs only to be told...
[SIZE=-1]BOOTMGR is missing. Press Ctrl+Alt+Del to restart
over n over same messege.
googled that its possibly down to the partition?
so.... anyone wanna tell me how i partition a harddrive that wont go into dos.
Do i run it as slave on the downstairs pc with a partition cd (will this work), or do i run it as a slave on my pc and run it that way via software (will my pc pick up the harddrive if it isnt partitioned?
thanking you
[/SIZE]
thanking you
[/SIZE]
