Thanks - I got 1 of 'em.http://cgi.ebay.co.uk/Clio-Engine-C...14&_trkparms=72:1683|66:2|65:12|39:1|240:1318
I used this person before and they're spot on
Should be fine.Would using 600 then 1200 grit suffice for the prep?
Then follow up with plastic primer?
Briefly:So will i be doing this right...?
-Sand down with 600 grit, then sand down with 1200
-Spray plastic primer, let dry
-Layers of paint
-Layers of laquar
Are them stages right? Do i sand wet or dry?
Briefly:
* key plastic surface with 600 wet & dry
* remove dust with tack cloth (or wash)
* 3 or 4 coats of plastic primer (15 minutes + between each coat)
* leave 24 hours then key again with 600
* remove dust as before
* 4 or 5 coats of colour (15 minutes + between each coat)
* leave 24 hours then carefully key with 1200 or 1500 wet & dry with plenty of water
* remove dust again
* as many coats of lacquer as you like (4+)
* leave 24 hours then refit
Ok so does the 2.0l 16v decal go on before or after the lacquer layer - I'm really not sure?
Ady reckons before the lacquer & I tend to agree.
Anyone else got any ideas???
Probably a stupid question but doesn't sanding it again with the 1200 grit dull the paint finish?
I'd say before the lacquer, thats what i'm going to do anyway
