Help from worcester please!
  evo 9 gt
Hi everyone, having problems with my clio 182. Cut a long story short, bought a race battery, fitted it all was well for a good few hours of driving, lights on, stop starting in traffic, fine. Went for a blast the following day and gave it some stick down a country lane and suddenly the battery light and stop light came on. Lights went dim, battery flat! Tried to charge it no good, so bought a new battery, same symptoms, battery light straight on an went flat after ten mins. Anyone have any ideas? Maybe alternator or a loose connection from a good hard drive through back lanes? Anyone have a diagnostic machine/rs tuner in worcester they could lend me,? Thanks alot
  evo 9 gt
Just to add, the fresh battery went flat after ten mins whereas the day before it was fine for a whole day! I'm pretty sure it's not the battery maybe a dodgy connection on the Alternator?
  Lionel Richie
have a look and check the big cable is still attached to the alternator, pretty common they rust and snap off, if its still on you need a multimeter across the battery and see what its reading with the engine running, below 13 and the alternator is toast
  evo 9 gt
K ill do that, my old man reckons I missed a wire off te battery for the alternator, is that a possibility? I have one main live and 2 smaller ones going into the fuse box then one negative that branches into 2. Doubt it's that though as it was fine all day the other day
