HELP: how do i change or get to the fog lights
Car  clio rs
i got some Hids lights to replce for the standard but cant seem to get to the fog lights -
doesnt help that the car is lowered, is there a easy way to do it or will the car have to be on a ramp, in a garage if so how much shud i be paying to get this done.
is there any1 local in london who can help me out or guide me for a drink:)
You should be able to get to it fairly easily if you have a decent hydraulic jack. Take the wheel off jack the car up as high as you can stick some axle stands underneath, peel the wheel arch liner back and you should be able to get to the fog light to change it, if the accoustic valve has been removed that give a little extra room on the passenger side.
Jack it up mate. I got underneath the front bumper to sort mine out and there should be a plastic bracket and two screws holding it.
It's not going to be impossible to jack up a lowered car. Drive it slowly onto a chock or something and then jack it up and keep it stable with axle stands.
Its easy.
Just changed mine too and if i can do it - it's easy!
Just jack the car up if you can, remove the splash guards, unscrew old one and replace.
if i remove the plastic bracket, is it easy to put back on. Cant it be done without removing the wheel, just had a setup done few weeks back
