Help! - How to remove 1.5Dci catalytic converter?
Car  Decked Dirty Diesel!
Hey guys,I have a 1.5 Dci and i'm looking to decat it, i've seen lots of posts on here listing the benefits and i've spoken to quite a few users that have done it and recomend it but i have no idea how to remove the cat, i have heard it is a pain to get out as it is right under the engine bay and pretty hard to get to.would really appreachiate it if anybody could write a rough guide on the easiest way to get to and remove the cat.Thanks,Lee :)
4 stud nuts on the cat to turbo joint ( above in engine bay )
2 nut/ bolts holding the cat to the exhaust flexi joint ( or solid )
3/4 bolts on the cat lower down , holding the bracket to engine.
undo all of those, top 4 will be fun as not much room.
undo hub nut ( drivers side )
undo 2 suspension strut bolts , the pull the hub away from the strut, carefully remove the drive shaft ( dont smack it with hammers, or you'll wreck the gearbox oil seals !! )
please only use axle stands when going underneith, and set them high so you dont struggle.
take cat out that side when drive shaft is removed.
How do you get to the top 4 bolts mate?
Mixture of 10mm sockets and ring spanners. 2 at the top in view, 2 below the cat bend but still on the square flange.
some of the nuts will not come off on there own, instead they might bring the stud out with them aswell. Just remember when fitting it all back,to do those four first as you can miss aline / cross thread them
P.s take engine cover off, you should have enough room between suspension turret and cat to get tools in.
Surprisingly they don't smoke allot more. But yes abit more gain, turbo is more free to spins so lagg is reduced' ie quick throttle response. Other than that, it's all turbo whistle noises
Lol sounds good, wonder if my girlfriend will notice if I de-cat the dci. It's already got a map, just need a dci 80/100 intercooler and turbo and a fresh map.
100 inter cooler is better of the lot ;) but are literally gold dust to get hold of. DCI 80 IC's are common as muck,shared on the kangoo's.
Turbo's are the same apart from the 100's so I wouldn't worry
I will say tho, ghetto de-catting was amazing but having a custom pipe made was much better for mapping
right, a rough guide as requested.
( might sound abit anal but oh well )
clio dCi mk2 cat removal ( de-catt procedure )
> whilst car is on the ground, crack off ( loosen ) drivers side hub nut and wheel bolts
> jack car up and place front end high on 2 axle stands ( if placing on sills, please use something with a groove in to prevent damage )
> remove wheel
!drive shaft removal !
two ways of doing this bit:
method 1:
> undo both lower strut bolts ( 2 bolt and nuts holding hub to shock ) ** take note which way around these go, ie nut which side **
> carfully push down hub , with care as brake lines are still attached, and pull out the drive shaft after fully removing hub nut.
> using something ie a crow bar, or blunt chissel , place bettween drive shaft and gearbox housing, gently prise drive shaft out ( no fluid should come out ) ** once drive shaft starts to come away, pull the rest off by hand **
method 2 :
> undo lower ball joint pinch bolt, remove with a punch tool and hammer, care to be taken to not f**k up the threads ( unless changing the bolts for new ones )
> hit the wishbone with a hammer and piece off wood. wishbone-wood-hammer. until ball joint is seperated from hub.
> undo the hub nut fully, the pull hub towards you and remove drive shaft from hub unit
! Exhaust and cat retaining bracket !
> underneith the car, you will see the join from cat to exhaust, held by two nuts/studs ( 13/12mm ) remove these two nuts and pull exhaust away ( DONOT lose the metal gasket that will fall out the joint ) and one bolt from cat bracket to exhaust ( not every dci has this )
> torch/ inspection lamp maybe needed for this bit.... whilst still underneith, you will see a bracket around the cat, this is held on by 3/4 PLUS the bolt that attaches cat bracket to the exhaust ( not every dci has this ) bolts are 13mm , 2 on the side of cat, and 1/2 on engine block. remove these and take cat bracket off.
! UP top in bay !
> jack engine up a little with a piece of wood bettween jack and sump ( assuming you dont have a dirt shield underneith ) basicly just supporting the load
> remove top left engine mount, four bolts around bottom to shell, 3/4 long bolts on mount to engine. ** do not over jack as bolts will not come out easy , if so let jack down a little until the engine is still supported **
>remove EGR metal boost pipe, held in by one 13mm bolt on rear, then pull pipe off ( pipe has two rubber seals, do'not damage these )
> using anything suitable to wedge bettween engine and bulk-head ( block of wood ) , move engine forward, not to heavy handed or the alternator/ aircon or oil filer may damage rear face of rad assembly.
> now you will see 4 nuts and studs, holding cat to turbo outlet. these can be tricky to do but still all accessable. 10 mm nuts. some of them may come out with the stud, but not to worry. use a combination of deep sockets/ extensions and spanners to remove these. ** please not some of them will be tight due to the metals constantly being heated through use **
! your cat should now be ready for removal !
> pull away from turbo housing, ** be carefull as brake fluid tank is just bellow **
> handle it down onto the sub frame or with help from someone else , pass it to them.
> rotate onto side and send out through the gap of where you drive shaft was.
De-catt at your hearts content :)
**** REFITTING ****
> place cat back in place, and do the cat to turbo bolts back up first!
> the rest is simply the reverse of removing
please note, I do not take any responsibility for damaged caulsed to your car when doing this job
