HELP! HT lead snapped off on spark plug
Car  Clio 1.2 Extreme
Thanks in advance for any help.
My car is the 1.2 16v. Was just carrying out the usual maintenance, filters, oil, plugs etc. Came to change the spark plugs, got 3 out of the 4 done with no problems at all. Come to do the 4th spark plug, closest to passengers side, and the bottom of the HT lead snapped off on the plug leaving behind the plastic end with the rubber inside. Managed to get an aerial with the end bent 180 degrees down there and pulled out the inner rubber, but now the plastic outer is well and truely stuck at the bottom on the spark plug. Tried with extra long nose pliers, screwdrivers,cant seem to get anything down the side of it or between it and the plug. Anybody got any suggestions i could try? or anyone had this problem before?
Ryan
