Mine did it for a while! Then it fixed itself? Lots of people have had trouble... East to sort if I remember! Someone will remember the name of the part, began with a "P"...
just gone to have a look at it again. idles fine at 900 rpm when 1st started up, once it was been driven for a little as a min starts idling high again. if you switch of the engine and start it up again straight away idle at 900rpm until driven again!
seems odd!
what does the potentiometer do?
also seems to be a clicking type noise coming from the engine! what could this be?
potentiometer is red and on teh throttle spindle, dont touch it, its not a problem.
ISCV or Idle Speed Control Valve is the sort of cylindrical shaped thing on the side of the throttle body, with a rubber pipe comming off it, start the engine and squeeze it, it should whistle.
Take it off and give it a good clean with carb cleaner........its might just be sticky.
This may sound stupid but you will more that likely find it to be the speedo cable. There is a speed input sensor at the top of the cable which supplies road speed info to the ecu, when you change gear and lift off the throttle speed input is sent to the ecu which then holds open the ISCV so when you put your foot back down there is no big flat spot. With a faulty sensor the ecu thinks the car is moving when it is not so again holds open the valve and the revs are higher. When you turn off the ignition the ISCV is reset hence when you start the car again it behaves ok. I bet you can rev and rev the car stationary and you cant get it to idle at 1400 yet when you go over thirty mph and 4000 rpm you will get the fault. As i say it may sound stupid the car idles high because of a speedo cable but believe me we have replaced quite a few.
Good point Nick - we had a similar thing happening to a customer car - replaced the ISCV, TPS etc and still happening. We then had the engine out, to do a clutch and when I put it back in I put a new speedo cable in as the old one was stretched, and hey presto no more idling issues.
now if im only out in the car for 5/10 mins it will still idle at 900rpm even if a rag it! however any longer driving and it idles at 14000 every time.
seems very odd. just cheakin it still seems like its the speedo cable
mate i reckon its the ISCV, mine was clicking as well like u say. if its sticking it wont let the engine idle correctly, only problem is they are quite expensive new! speedo cable is a bit cheaper to try 1st...
