HELP!!!!!! INLET MANIFOLD ISSUE!!!
Car  182,golf vr6,206gti
IVE JUST SWAPPED INLET MANIFOLDS ON MY CLIO 172 (COSMETIC REASONS) AND WHEN I FITTED THE NEW ONE AND STARTED THE CAR UP IT JUST REVVED AND CARRIED ON REVVING???ANY IDEAS???
Air is getting in to the engine through somewhere other than the throttle body. As ^ said, check the brake vacuum take off, also make sure all the bolts are tightened down properly, did you use a new gasket?
thanks for the help guys, ive solved the problem....sort of i had to put my old manifold back on and everythings fine now. the new manifold on closer inspection has 2 nipples near the throttle body (directly behind the sport badge as you look at manifold) wheras mine only has 1! any idea on why?have they sent me wrong manifold maybe one off of a 182 or something
You will need to blank off one nipple and all will be fine. 172 manifold differs slightly to the 182, you probably had a bolt you couldn't get in too?
yes there was a spare bolt on the top left at the back, it didnt seem to affect how secure the manifold was it seemed on very tight. which nipple do i blank off of the two there is one on the right and one on the left? my feeling is blank off the left one (as you look at engine)
