HELP lights not working
ok front and rear parking light, and front full beam not working, bulbs are fine every time i change the fuse it just goes bang?
help
regards
mandeep
if its not the bulbs not the fuse then it must be a bad connection somewhere you have to check the wiring!
Check all the relays are plugged in there under just above the passenger feet go check there all plugged in if thsi isn't losoe them start going though the wires.
