Hello all, this is my first post, i have been browsing the forum and its a great source of information.
I recently bought a 51 plate 172, it needed a few things doing for the mot and was pretty tatty, i have sorted it all out now, but have found a new issue where the car pulls hard to the right under acceleration, and then when you let off it jerks back to the left. (the steering wheel doesnt move from the straight position.)
Since having the car i have changed the suspension all round, for low milage cup items, new discs and pads all round, and a different set of wheels, along with having the tracking done by a trusted garage, whom i always use for alighnment.
I have thinking the cause is engine mounts, i decided to investigate the top gearbox mount, as when i grabbed hold of the inlet and swung the engine, there was a lot of movement, so out came the battery and the top gearbox mount, didnt even have a nut on the bolt out of the top of the box. God knows how long this has been like this, so i replaced with a new nut, and a lock nut to make sure it didnt go missing again, and still the problem persists, i then noticd that the gearbox top mount was egg shaped, so i have replaced that, and you guessed it, still there..
Has anybody else had this problem before? Its starting to get costly..
Any help much appreciated,
Cheers Dan
Cheers Dan
