help needed asap
Car  clio t4 turbo
hi i have a clio mk1 rsi but its fitted with a volvo 480 turbo engine and my clutch cable has just snapd wot clutch cable is it that i need is it the clio1 or a volvo 480t cable.thanx
Surly if you get the 480 T Cable you cant go wrong asuming its got that gear box in it. You can jst cut the cable to the length you need, as i asume it will be longer than a clio cable.
Hope this helps
